Headlights malfunction. 88 240dl
Old Apr 1, 2009 | 01:25 PM
skoulascores's Avatar
Default Headlights malfunction. 88 240dl
My headlights out of nowhere both went out on me at the same time the other night. I didn't think it was the bulbs but replaced them anyways. Nothing. Took out the headlight switch, didn't think it was that but replaced it anyways. Nothing. My high beams will still work if I hold the high beam lever back but can not click them on to stay on. I am somewhat lost at this point. I do not think it is an electrical problem because the fuse is still intact. Could it be though? I have referred to my chiltons and cannot really find much information about this. Any help would be much appreciated. Thanks
Old Apr 1, 2009 | 01:57 PM
bubba240's Avatar
I would investigate the hi/low beam relay by the battery. Just a guess ...
Old Apr 5, 2009 | 06:14 PM
redblock's Avatar
do you have dash lights if not check the relay( K relay ) in the center shelf as it shuts the lights off when the ignition is turned off sometimes the contacts at it will meltdown at it
Old Feb 2, 2013 | 11:36 AM
govango's Avatar
I am having the same exact problem but my dashlights are on. Any suggestions?
Old Feb 2, 2013 | 11:38 AM
sicnarf's Avatar
Checked the light relay.?
Old Feb 2, 2013 | 11:46 AM
govango's Avatar
well, i just went out to check it & the headlights work. but they didn't last night. i have this problem a lot with my 87 240dl where lights will not work one day and work the next.
Old Feb 2, 2013 | 03:13 PM
sicnarf's Avatar
Either faulty relay or faulty light switch. Would also be good to clean upp the groundings.
Old Feb 3, 2013 | 02:16 AM
analogies's Avatar
Default bulb intetrity sensor might be the culprit
if the high beams work...I would think ....one of the two relays is bad since the turn signal sends power to the light fine....WAIT the high beam is that big silver on by the battery...next to the black plastic one...
relay by the fender or inside the car OR bulb integrity relay or sensor...the big red/yello/black circle under the steering wheel support member(?) with a dozen or so connections to it...it could be aluminum housing...
check all the fuses and relays before buying the Bulb Integrity sensor as it is around 60 to 78 bucks....
see pictures..yours should be red..
Attached Thumbnails Headlights malfunction. 88 240dl-bulbred.jpeg   Headlights malfunction. 88 240dl-bulbyellow.jpeg
VDriver24093
Feb 21, 2011 04:35 PM
badgers
Jan 31, 2008 05:35 AM
imsasun
Nov 26, 2005 09:23 AM
sghokie
Apr 27, 2005 01:52 AM
