Heater Core replacement
Old Apr 20, 2011 | 11:56 PM
endneu913's Avatar
Default Heater Core replacement
........ Any one have a handy link to a step by step write up!?
Our 78 242 decided to start blowing smoke from the vents and fogging up the windows bigtime. Is this the tell tale sign of a bad heater core, or is there any other culprit parts? Thanks!
- Grae
Old Apr 23, 2011 | 08:56 PM
endneu913's Avatar
Not so much?
Old Apr 24, 2011 | 01:46 PM
Whitebrick's Avatar
It looks like all Volvo forums everywhere are being deserted lately- hopefully just holiday travel keeping them empty!
That definitely sounds like the heater core- read through this if you haven't already...
Heating and Air Conditioning
Parker
Old Apr 24, 2011 | 02:00 PM
Whitebrick's Avatar
Not that I'm much more help, giving you FAQs on the later series. Trying to find where I saw someone describe their ordeal- actually, I think on 240s you can save a lot of time and cut into the side of the heater with a dremel tool.
Old Apr 24, 2011 | 09:07 PM
endneu913's Avatar
No, i appreciate the help. Im thinking about doing the cut n pull cheater method.. Ill update
Old Sep 24, 2011 | 10:28 AM
ElJefe91's Avatar
Default Heater Core Repleacement Link
1998 Volvo V70 - Heater Core Replacement W/ Pics - Volvo Forum : Volvo Forums
Old Sep 24, 2011 | 03:26 PM
jagtoes's Avatar
Don't go overboard on this. It may only be a high humidity or a frozen evap causing the problem. The most obvious question is do you smell antifreeze. If so then you have a leak. Also do you have any antifreeze on the floor of the car or the floor of your garage. What were the conditions when you got the mist out of the vents. Has it done it again. Does it do it with the AC on or with the heat on. Smell would be the key.
rvinson2
Aug 31, 2015 07:48 AM
ycartf
May 6, 2013 11:19 AM
baustin
Mar 21, 2013 10:32 PM
Wovolvorine
Dec 8, 2010 12:06 PM
azeezn
Dec 12, 2005 10:50 PM
