heavy missfire 1990 740 16 valve
Old Jun 14, 2016 | 04:05 PM
bluefrontier@att.net's Avatar
Default heavy missfire 1990 740 16 valve
My 1990 740 16 valve started to missfire terribly all of a sudden.
The head gasket was replaced 1,500 miles before this due to leaking oil into the coolant. A shop did the work. Did NOT mill the head; said it was unnecessary.
Removing the plug wires from the forward two cylinders actually makes the engine run smoother.
timing / balance shaft belts checked OK
Compression checked OK
What is going on??
The shop can't figure it out.
Old Jun 15, 2016 | 08:53 AM
lev's Avatar
lev
What is going on??
Codes? Power stage? May be fuel related?
Old Jun 15, 2016 | 10:33 AM
Shop is trying to figure it out.
I'm thinking the gasket blew between cylinders but mechanic said compression was ok.
Old Jun 16, 2016 | 04:58 AM
It was a cracked distributor cap. go figure.
Austin_Volvo_Guy
Sep 8, 2013 06:41 PM
stonehands
Aug 2, 2011 09:41 AM
850_Volvo_Dan
Jun 17, 2010 01:47 PM
andyr
Jul 19, 2007 07:02 PM
kennys s40
Oct 23, 2006 10:22 PM
