Help!!! 91 240
Old Apr 24, 2017 | 07:50 PM
MrMorones's Avatar
Default Help!!! 91 240
Hi all. I need some help. I have a 91 240. After car warms up my car will die. I have had it die while idle, while accelerating, or while putting in gear after parked.
I have replaced fuel pump(external), fuel filter, in tank pump, strainer, fuel pressure regulator, and fuel relay.
What am I missing? I am losing sleep over this. Please any help?
Old Apr 24, 2017 | 10:57 PM
MrMorones's Avatar
Update. So after driving around for a bit pulled over left car in drive with foot in brake. Less than two mins later, car died.
Old Apr 24, 2017 | 11:20 PM
replacing random parts without first diagnosing whats causing the problem gets expensive fast.
Old Apr 25, 2017 | 05:47 AM
act1292's Avatar
When it dies - does it start right back up? If not, check for spark and fuel at the rail.
Old Apr 25, 2017 | 09:02 AM
silvermine's Avatar
you could check the condition of the distributor cap + rotor
Old Apr 25, 2017 | 07:50 PM
lev's Avatar
lev
Pretty sure, like 99%, that you need a new CPS Crankshaft Position Sensor... Buy an OEM.
mojo
Jan 6, 2013 06:40 PM
uenvyboykin
Dec 29, 2008 02:47 AM
dennisimo69
Apr 16, 2008 06:38 PM
markjenross
Nov 7, 2007 08:02 PM
denbass
Oct 23, 2007 03:45 PM
