Help, insight, NASA Engineers Unit!240 Odometer internal eletronics trouble shooting.
Old Jul 22, 2020 | 05:16 PM
93240SW's Avatar
Default Help, insight, NASA Engineers Unit!240 Odometer internal eletronics trouble shooting.
Not my new 25 tooth gear, possibly the Service Light Rest "switch"?! See pic I realy think it the odometer "motor?" Pic. Notes per pic. Bentley Manual no help. See pic
Bentley Manual 83-93 240 Editorial closing 07/1993 this is a 91 240, Im doing side x side comparison with b my 93 Odometer, the spring, gear, and trip odo reset all replaced.22 July 2020
Gear motot? Should I beable to do see pic 3.
The is a magnetic \"pull/resistance but nothing snapped, cracked, popped, or made my heart sink. Ive manually advanced the speedo 7 miles trying to rule out the 25 tooth gear. It gotta be this motor.
Made a spring. 3rd reinstall for test if its a spring, gears, or motor on the gears?!
Plastic post broke HAND DRILLED a very small hole away from any circutry , panel, resistet, fuse, or otherwise eletronic devices.
Old Jul 22, 2020 | 05:54 PM
edvard's Avatar
It could also be the chip. I had a 3-1-1 code that said the ECU was missing a signal from the speedometer. I ordered a new speedo chip (ITT2115) and that fixed my code, but as a bonus, my odometer started working again! Have you had that code show up?
Old Jul 22, 2020 | 06:02 PM
93240SW's Avatar
Default Its a bone yard restoration
Its missing instrument bulbs so hard to say if its telling me anything, speedo track mph, bulbs that are in it work. E break, turn signals headlights, shift indicator.
Organ donor
Old Jul 29, 2020 | 09:13 AM
act1292's Avatar
It very well could be your 2115 chip as it is the source of pulses that drive the stepper motor you are looking at. For a full schematic of this circuit take a look at this web site. Great work at reverse engineering.
Electronic Speedometer Notes
Fogducker
Mar 17, 2016 02:18 PM
rbrunn
Apr 22, 2011 06:18 PM
jjmilburn
Jul 8, 2009 09:27 PM
montysano
Apr 5, 2008 10:12 AM
pisque
Jun 30, 2005 03:03 PM
