Odometer repair
Old Mar 21, 2011 | 03:04 PM
rbrunn's Avatar
Default Odometer repair
Just put in a new gear for the Odometer but it still does not work. It was suggested it might be the motor. Is there any way to test the motor?
Old Mar 21, 2011 | 03:23 PM
zloetakoe's Avatar
Did the gear you replaced have missing teeth?
If it did, it was probably the gear. If it wasn't missing any...???
Old Mar 22, 2011 | 10:25 AM
labelsdc's Avatar
I had the same issue. You might want to take a dust remover spray and spray where the gear is. There was miniscule pieces of teeth stuck in there preventing the gear from turning. It definitely worked for me. Try that first. Good luck
Old Apr 22, 2011 | 06:18 PM
rbrunn's Avatar
Default odometer repair
Replaced gear, blew out assembly, gears and odometer turn manually but not when installed. I checked all the connections and they seem ok. A round connector, an L shaped white connector to the board, a half moon connector, and a red/yellow connector for the overdrive. Am I missing anything or could it be something else.
Shaggin240wagon
Oct 16, 2013 12:04 AM
dgjohns
Dec 8, 2009 07:01 AM
Sambar Stag
Aug 30, 2009 07:43 AM
ron747
Oct 17, 2008 01:16 PM
montysano
Apr 5, 2008 10:12 AM
