HELP my 81 Volvo 240
Old Jul 10, 2008 | 06:32 AM
alwayssomething's Avatar
Default HELP my 81 Volvo 240
Ok I just bought this car because the guy could not get it running. I put a battery in it and it started right up, but would stall if you did not let it idle for about a minute. I drove it around for a few days and then one day it would not start, it would just crank and you could not hear the fuel pump. I tried a couple days later and it started,now it will not start again it just cranks.Please help. Also not sure how to use the OD button. Thanks for any help
Old Jul 10, 2008 | 08:12 AM
wojeepster's Avatar
Default RE: HELP my 81 Volvo 240
well fuel pump relay could be the problem. They tend to fail on volvos you can check it with a multimeter before you purchase one. Check for spark with timing light, check for gas and go from there. You have two fuel pumps and in tank pre pump and a main fuel pump under the car. In tank prepump usually shows up when you are under half a tank of gas so if you are (under 1/2) add gas and see if that helps.
Old Jul 11, 2008 | 03:45 PM
obaloney's Avatar
I agree with wojeepster. Do what you can to troubleshoot the fuel pump first. And as for the overdrive, if it's a stick shift, just depress the clutch when you're in 4th and press the OD button.
I also recommend you get a Bentley's Volvo service manual if you keep the car. Lots of good advice. And find yourself a good mechanic near you, you'll need him/her, probably him.
Obaloney
Old Jul 11, 2008 | 09:03 PM
wojeepster's Avatar
I also recommend a great small book. How to diagnose and repair automobile electrical systems by Tracy Martin about $18 amazon.com
mojo
Jan 6, 2013 06:40 PM
journeyforce
Dec 11, 2012 08:19 PM
uenvyboykin
Dec 29, 2008 02:47 AM
dennisimo69
Apr 16, 2008 06:38 PM
markjenross
Nov 7, 2007 08:02 PM
