HELP Oil Spray
Old Jun 6, 2010 | 12:05 AM
saberjk2's Avatar
Default HELP Oil Spray
There is oil coming from somewhere from the left side of the motor, when looking at the car straight on. I just replaced the air intake hose but I don't know why that would be of any interest. Help?!
1987 240 DL
Old Jun 6, 2010 | 09:06 AM
Beardog's Avatar
left from the driver's perspective or from the mechanic's perspective
Old Jun 6, 2010 | 10:26 AM
tedv's Avatar
The front camshaft seal tends to ooze down and to the left leaking over the water pump seal in the LEFT FRONT. If the leak is further back, I'd suspect the Head Gasket. Take a mechanic's mirror and look in the places where the head meets the block. If there's oil there going down, there you are. I'd wash the motor first, then look for the fresh leaks. Many cars are so covered in oil, it's hard to tell...
Old Jun 6, 2010 | 12:26 PM
saberjk2's Avatar
UPDATE:
I took a look at the car in the daylight and there is oil dripping from places that it shouldn't drip from, I.E. the mud flaps (front and rear), from the middle of the car, middle-rear, and a huge puddle under the engine.
BearDog: Mechanic's left, driver's right.
tedv: I am definitely going to have to wash off all the oil on the engine.
Old Jun 6, 2010 | 01:56 PM
tedv's Avatar
Whoa, there! Mud flaps dripping oil? This sounds like a LOT of oil, more than an engine even holds. Do you live in the Gulf somewhere? Been driving on a Louisiana beach?Do you have ANY oil in the motor at all?
Old Jun 6, 2010 | 07:38 PM
saberjk2's Avatar
Tedv. I really wish I had been driving on an oily beach. At least I wouldn't have to directly deal with it. There is NO oil in the engine.
Pictures to come.
Old Jun 6, 2010 | 07:56 PM
saberjk2's Avatar
Old Jun 6, 2010 | 08:27 PM
tedv's Avatar
Looks like the front cam seal... No big deal. You can do it yourself, may be... A couple of $ for the seal, valve cover gasket...
Old Jun 6, 2010 | 09:11 PM
saberjk2's Avatar
Should I replace any other seals around the engine if this one has broken too?
Old Jun 6, 2010 | 09:37 PM
tedv's Avatar
That one is by itself... so, there is not much labor saving.
Old Jun 7, 2010 | 10:54 AM
Cherry_Pirate's Avatar
if it's cam seal like ted says, that's an easy fix. Make sure you mark where the cam shaft pulley is at in it's rotation and don't turn the lower pulleys or you are going to have to reset the timing and that's gonna require a bunch of **** to come off. Including the dreaded crankshaft pulley.
The top seal pops out with a butter-knife and some perseverance. It should be obvious if that's the problem once your there.
Old Jun 7, 2010 | 10:59 AM
saberjk2's Avatar
From what I can tell, there is only one camshaft seal. So do you mean I should replace the front crankshaft seal? Because the crankshaft has a front and a rear seal.
Old Jun 7, 2010 | 11:25 AM
you have pull off the cam pulley and there is a seal in the front behind it.
http://www.preludeonline.com/images/...ms/CamSeal.jpg this is, admittedly, not a volvo, but they look similar so I am using this pic. See that black ring around the camshaft? When you take the pulley off and pull back the plastic backing of the case you will see that... or a lot of oil... or if nothing, then that's your issue haha.
P.S. http://www.ipdusa.com/version.asp?st...ID=0&V_ID=2579 there's a rear cam seal, it has a cover over it so it might not be obvious.
rolotamossy
Dec 15, 2021 04:07 PM
angeliabur
Sep 21, 2009 01:17 PM
chef
Sep 16, 2009 11:30 AM
bobrd37
Sep 4, 2008 02:26 PM
BuildinAs70
Jul 28, 2008 12:31 PM
