Hesitation on acceleration 940 GL
Old Jun 15, 2016 | 12:53 PM
bjl7564's Avatar
Default Hesitation on acceleration 940 GL
1992 940 GL
1. on acceleration from dead stop, vehicle hesitates and rpm fluctuate between 1500-1800 rpm range. Feels as if you are pushing down and letting off gas pedal
Car has slight bucking until it can reach 2000 rpm. Lasts about 20-30 secs.
2. Once over 2000 rpm range no further problem
New fuel filter
fuel pump primes
new quality wires
cleaned master air flow indicator
Old Jun 24, 2016 | 07:28 AM
Moved to 940 section.
Old Jun 24, 2016 | 03:44 PM
lev's Avatar
lev
If you don't have 'tune up' issues, meaning the car is in good running order ignition wise, what you probably have is a failing fuel pump...Try and measure the fuel pressure at the rail when this symptom is present (I know, easier said than done!).
Old Jun 23, 2024 | 03:41 PM
megames's Avatar
I have the same did u fix it yet?
megames
Jun 23, 2024 08:02 AM
forzaV12
Aug 10, 2017 08:42 PM
ms000
Feb 7, 2017 01:10 AM
Fernando Cabezas
Sep 22, 2009 05:25 AM
loonatic72
Feb 1, 2007 08:34 PM
