hissing noise loss of power?
Old Jan 15, 2009 | 09:00 AM
akorcovelos's Avatar
Default hissing noise loss of power?
So my '88 240Dl started doing this a couple days ago and it's really stumping me. The car runs/drives fine for a bit, then it will start making a loud hissing noise which seems to be coming from the passenger side of the engine bay when I apply the throttle. The more throttle I give it the louder the hissing gets and the worse the power loss is. This problem comes and goes rapidly.
From searching all I can find is it may be the cat, but would that cause the hissing sound from the pass side engine bay?[/align]
Old Jan 15, 2009 | 11:23 PM
cimeron's Avatar
Default RE: hissing noise loss of power?
the hissing may be a small leak in your coolant tank. im not sure for a 240, but in a 940 the coolant tank is along the passenger fender, and when the engine is running the tank has considerable pressure
Old Jan 16, 2009 | 12:55 AM
fredbyte's Avatar
Check for leaks around your waterpump. Free guide to waterpump replacement at www.stepbystepvolvo.com.
Old Jan 16, 2009 | 09:48 AM
blue goose's Avatar
The hissing could be caused by a leaky exhaust manifold, either cracked manifold or blown gasket. I've had a cracked exhaust manifold that made a hissing sound. Or the O2 sensor might be loose.
Wesley brown
Oct 7, 2014 10:12 AM
98 Volvo S70 T5 Turbo
Jul 25, 2012 04:53 PM
jacobblount
Jun 19, 2008 12:13 PM
Brucester1313
Oct 22, 2007 10:17 PM
kaz
Jul 7, 2006 01:11 PM
