Horsepower adding to a 93 244 na ????
Old Apr 21, 2025 | 08:41 PM
tim355's Avatar
Default Horsepower adding to a 93 244 na ????
Would like to boost the hp, ( or acceleration) on my stock 93 244na. It is in pretty good shape, Engine is clean inside, has 200k..auto. I was thinking about retarding the cam ? and maybe higher flow injectors. Thanx for your input.
Old Apr 22, 2025 | 08:44 AM
act1292's Avatar
You could change the cam using a kit something like this:
https://www.ipdusa.com/products/8771...mbs=0,986,1061
I'm not sure how much performance you would gain. Higher flow injectors will mess up the fuel mixture unless you are planning to change out the fuel map using a different ECU and properly tuning it.
bulichproof
Feb 19, 2019 09:41 PM
Oregonite
Jan 5, 2013 10:21 PM
michale
Jun 12, 2010 04:56 AM
MrBusterGuy
Jul 16, 2006 09:50 PM
