Which hose should I check/replace 88 740T
Old Sep 15, 2008 | 10:48 PM
407flyer's Avatar
Default Which hose should I check/replace 88 740T
Hi folks,
My 88 740T has an acceleration problem thats been going on for a while. If the car has been sitting for a few minutes with the engine off, it will accelerate hard in first gear until the boost gauge begins climbing past about 2/3 max boost, then the acceleration stops abruptly. Once it has done this once, it will accelerate poorly throughout the entire rpm and boost range. If you shut the car off for a little while it does the same thing again. The engine does not cut out, no smoke, no back-fire, no knocking... just no power.
I have replaced the mass air sensor, the foam in the air filter box has been removed, the plugs are new (the old ones showed normal light gray deposits), and it has a new distributer. I'm beginning to think that an intake air hose is collapsing under acceleration, but I have no idea which one to start with.
Any ideas?
Old Sep 28, 2008 | 11:04 AM
bli745's Avatar
Default RE: Which hose should I check/replace 88 740T
Does it do it stationary or just under load?
Tom Alexander
Oct 2, 2013 12:49 AM
schoolloans
Jun 18, 2009 08:34 PM
777funk
Mar 17, 2009 01:54 PM
ko_kidd
Aug 25, 2006 08:53 PM
jc740T
Nov 22, 2004 10:56 AM
