How do I adjust the idle on a 1993 240?
Old Mar 13, 2010 | 09:48 PM
briang232000's Avatar
Default How do I adjust the idle on a 1993 240?
Could anyone tell me how to adjust the idle on a 1993 240? Thanks.
Old Mar 13, 2010 | 10:46 PM
nepatternmaker's Avatar
According to my Haynes manual:
1. Engine at operating temp
2. ground the blue/white test lead near the battery, NOT the red wire, this will damage the O2 sensor. Turn off all lights and accessories.
3. Turn idle bypass screw (or ****) to adjust idle speed to recommended idle speed shown on underhood sticker. Idle speed screw is under the intake hose at the drivers side of the throttle body.
4. Remove jumper from blue/white test lead. Idle should increase slightly. If not you may have problems with the air control valve or it's circuit.
dave
Old Mar 14, 2010 | 05:19 PM
mikkowus's Avatar
Possibly clean the throttle body while you are at it.
98XCFxRUpR
Sep 28, 2014 12:16 PM
jws
Dec 30, 2011 08:09 PM
SgtCheeseNOLS
Mar 22, 2011 06:56 PM
schnepel
Mar 18, 2010 10:10 PM
Colin Carter
Oct 3, 2005 10:09 PM
