How hard is it to replace a flam trap?
Old Apr 30, 2011 | 11:23 AM
92_240_sedan's Avatar
Default How hard is it to replace a flam trap?
Im asking becuase i have been told a clogged flame trap could cause me to blow my rear main seal. I would prefer it that did not happen.
Old Apr 30, 2011 | 03:12 PM
guest01's Avatar
if it's your first time and or you have large hands/arms, a pain in the ***.
I've done dozens of them, so my opinion is bias.
Old Apr 30, 2011 | 08:32 PM
tony1963's Avatar
The flame trap is easy, the oil separator is more work. It is not hard. For the novice, about 4 hours. Remove the intake and the oil separator is right there bolted to the block.
The last one that I did took 1.5 hours start to finish.
Old Apr 30, 2011 | 08:38 PM
jagtoes's Avatar
Should take maybe 15 minutes to do. Remove the hose and pull the screen out. You don't need to replace it but if you want use the plastic insert.
Old Apr 30, 2011 | 09:15 PM
guest01's Avatar
I forget all the euro. lingo. the flame trap is easier, I thought you meant oil trap.
if you haven't worked on these cars before the engine can look more cluttered then it is, until you find the right angle to put your arms in, etc.
Shibby
Oct 8, 2025 11:32 PM
Bmgrlfl
Jun 12, 2021 03:23 PM
Beachbum
Sep 11, 2012 10:54 AM
rooster11
Jun 30, 2011 12:33 PM
dholmes83
Feb 26, 2010 09:20 PM
