How to read ECT voltage/resistance from ECU?
Old Jul 29, 2018 | 05:45 PM
Sufarry's Avatar
Default How to read ECT voltage/resistance from ECU?
Well. I don’t know much about electronics and ****. So. Replaced the coolant temp sensor because I was having hard warm starts.
Anyways, I replaced it with a new one, now my car starts perfectly when warm.. however, it doesn’t start when the engine is cold now.. unless I give it lots of throttle and keep the RPMs up until it warms up some.
I tested the sensors resistance and got normal numbers, so I think she sensor is fine... however, I tested the resistance from the plug to the ECU and this is the reading I got... is this normal?
How can I test the plug from the ECU side so I can test while the engine is running with the plug connected to the sensor?
Old Jul 29, 2018 | 05:55 PM
tony1963's Avatar
I don't know if there is a "standard" reading between the connector and the ECM. There is no resistance built into that circuit and how the ECM computes temperature is the resistance through the circuit. You go from typically very little reference voltage when cold to a full voltage reference when "hot".
The connections are typically checked for continuity between the terminal and the other end of the harness at the pin for the computer. What year is your car?
Old Jul 29, 2018 | 05:56 PM
Sufarry's Avatar
Thanks for the quick reply, mine is a 1992
Old Jul 29, 2018 | 08:43 PM
to measure the CTS resistance from the ECU, you unplug the ECU and measure the resistance of the CTS pin to a ground pin at the ECU plug. ideally you also do this at the ICU as the CTS has two elements, one connected to each of the ICU and ECU.
the CTS is an inverse resistance thing, its high resistance when cold, 10 or 20k ohms, I think? and low resistance when hot, like 600 ohms or something. the correct values are in the 7xx/9xx FAQ for LH 2.4 cars.
Old Jul 30, 2018 | 08:32 AM
Sufarry's Avatar
Thanks for the reply!
Do you have a diagram on the ECU of which pin is the CTS pins?
Old Jul 30, 2018 | 10:07 AM
its ECU pin 13, and also ICU pin 2 on LH 2.4 cars (1989+ non-turbo and 1990+ turbo). ECU ground is pin 5, ICU ground is pin 11. measure the resistance at the ICU or ECU plug, with it unplugged from the ECU/ICU,
resistance of the sensor should be as follows:
32F - 6000 ohms
68F - 2300 ohms
104F - 1300 ohms
140F - 600 ohms
176F - 300 ohms
212F - 190 ohms
all within about +/- 10%
I'd suggest getting the engine nice and hot, pulling the plug measuring it for the warm value, then wait for it to cool down to ambient and measure it again.
https://www.volvoclub.org.uk/faq/Eng...ingECTFailures
Old Jul 30, 2018 | 10:24 AM
Sufarry's Avatar
32F - 6000 ohms
68F - 2300 ohms
104F - 1300 ohms
140F - 600 ohms
176F - 300 ohms
212F - 190 ohms
What's the best way to reach these pins? I saw the ICU ( Black box on the firewall? ) and I saw the ECU ( Silver box on the right side of the passenger foot well ), how do I go about getting to the pins?
Old Jul 30, 2018 | 10:25 AM
unplug the connector from the ECU or ICU, and carefully probe the pins on the inside of the plug
Old Jul 30, 2018 | 10:26 AM
Sufarry's Avatar
Are they numbered?
Thanks for all the replies and help. I'm good with mechanical things, but wiring and electrical stuff confuses me a bit!
Old Jul 30, 2018 | 11:24 AM
last one I looked at, I could see tiny molded numbers next to each pin on the ECU side of the harness plug. required a small bright flashlight to see.
Squirt
Dec 29, 2020 02:53 PM
TV540
Aug 14, 2019 09:46 AM
Sufarry
Aug 11, 2018 02:09 PM
markisboss
Apr 27, 2008 01:23 AM
markisboss
Apr 20, 2008 06:33 PM
