Fried ECU?
Old Apr 20, 2008 | 06:33 PM
markisboss's Avatar
Default Fried ECU?
Does anyone out there know if an ECU will fry (cook, ruined) by a battery charger?
I am trying to figure out why after changing my ect sensor two times, I am still getting fault codes 123 and 224 both of which point to a fault in that sensor. I went ahead and took ohm and voltage readings at #13 and 5 at the ecu and although the ohm reading at (68F) was within normal, the voltage reading was way high, like 11-12 volts. I read that NO voltage would indicate a bad ecu but is that the case with a high reading? I do know that when I had the charger hooked up the car did some strange things. The car does start and run but poorly and with the codes mentioned above.
Thanks to any who post!
Luke93 850
Aug 3, 2011 07:22 AM
aphelius
Apr 10, 2010 08:08 AM
1Gray760T
Nov 13, 2009 08:19 PM
98T5
Sep 3, 2009 09:08 PM
Riculus
May 17, 2007 09:47 PM
