how to replace valve cover gaskets
Old Nov 17, 2010 | 09:50 PM
volvoQ's's Avatar
Default how to replace valve cover gaskets
740 turbo, 1990
I bought a valve cover gasket planning on switching it out quickly like I have done on previous cars, but then I read I can mess up the valves and its a really difficult job?
Advice please and thanks as always.
Old Nov 17, 2010 | 10:29 PM
swiftjustice44's Avatar
Mess up valves? Only if you have a seizure or something similar..It's quite simple...just use a daub of silicone where the gasket curves up around cam and dizzy...front and back. Very straight forward.
Old Nov 17, 2010 | 10:55 PM
volvoQ's's Avatar
I thought so. I've done valve covers in the past. Starting reading about how there was a device to clamp down on the valve covers while you unfasten the bolts so the cam/valves don't jump or bend. Was confused and frustrated. Glad to hear it's straight forward. Should I use the silicone on the valve cover side, not the head side? I have the rubbery/fiber type gasket (if that makes sense). It's rubbery but relatively stiff. So I don't need to put any gasket sealer anywhere else? Thanks for your help as always.
Old Nov 18, 2010 | 01:42 AM
Typhoon's Avatar
It's a SOHC redblock yes? (black valve cover)? If so, it's a very easy job, but clean around the front and rear cam saddles and smear a little sealant into the corners there as Swiftjustice just observed.
Regards, Andrew.
volvoQ's
Nov 29, 2010 10:36 AM
volvoQ's
Nov 13, 2010 09:21 AM
Bubs
Jan 11, 2010 09:35 AM
mindenm
Nov 1, 2007 05:16 PM
SilentBob
Nov 14, 2006 09:09 PM
