I need some direction please 240 wagon
Old Dec 29, 2010 | 04:52 PM
4bnbad's Avatar
Default I need some direction please 240 wagon
I posted but this is the latest up date on my '92 240 wagon auto matic
I had new starter, new plug wires, new distributer cap, new rotor, new coil,
air cleaner is clean. Starts up instantly, idles smoothly, but no power, top speed 10MPH, When I floor it I hear a lite popping from air cleaner not the sort of thing you'd get with a crossed wire or out of time, but a too lean popping.
Brings me to the conclusion, either fuel pump or fuel filter.
Your thoughts direction? I'm not fond of being a parts changer in the elusive search for faulty part. Help me to pin point. 4bnbad
Old Dec 29, 2010 | 10:30 PM
ed7's Avatar
ed7
Popping through the air cleaner may indicate a burned valve or carbon crud stuck on a valve. Do a compression check, you may have more than one problem. Also pressurizing the cylinders aka leak-down test can tell you more.
Check valve timing, maybe the timing belt jumped or tensioner a bit.
Ed
Old Dec 29, 2010 | 11:10 PM
4bnbad's Avatar
sTARTS INSTANTLY AND EFFORTLESSLY AND IDLES SMOOTHLY, I'm going for the main fuel filter. Will report back tomorrow night. 4bnbad
Old Dec 30, 2010 | 07:31 PM
NCVOLVO940's Avatar
if it IS the fuel pump, you usually want to change the filter as well... cheap insurance.
Old Dec 31, 2010 | 11:21 AM
4bnbad's Avatar
Default 240 wagon
I changed the large canister fuel filter, a 10 minute job that took the best part of the day. Is it necessary to bleed air from injectors?
I started car not clearing it's throat.
Lansdowne
Sep 22, 2014 01:02 AM
Truck Turner
Feb 1, 2013 07:52 PM
bigdaddyrdpjr
Oct 13, 2007 09:47 PM
Branan
Dec 8, 2005 09:15 PM
Colin Carter
Oct 3, 2005 10:09 PM
