Ignition Coil Too Hot to Touch?
Old Aug 13, 2012 | 06:05 PM
traderssd's Avatar
Default Ignition Coil Too Hot to Touch?
Have an early 80's 240 that usually runs great. Every once in a while the fuel pumps will just shut off while driving and stall the car. Usually it will start right back up again or certainly within a minute or two and run ok. I put in a new fuel pump relay thinking that was the problem but it still does it.
I've noticed that the ignition coil gets really hot and was wondering if that could have something to do with it? I heard somewhere that if the ECU senses a problem in the ignition circuit, it will shut off the fuel pumps. Does anyone know how hot the ignition coil should get or if this could be my problem? Mine get too hot to touch after about 10-15 minutes. What actually turns the fuel pump relay on and off?
Thanks a lot
Stuart D.
Portland, Oregon
Old Aug 13, 2012 | 08:49 PM
early 80s could mean a K-Jet or LH-II or LH2.2 car depending on the year. the ECUs are totally different for K-Jet (aka CIS) than for LH (EFI)
Old Aug 13, 2012 | 09:38 PM
traderssd's Avatar
My car is an '83 with the Jetronic ECU if this helps. But regarding the ignition coil, how hot should it be after about 15 minutes? Mine is nearly too hot to touch. Is this normal? Does anyone know?
Old Aug 13, 2012 | 10:49 PM
coils get pretty warm, but they shouldn't be getting 'hot'. I'd wonder if the ignition power module isn't having a problem and dumping too much DC current into the coil or something. I'm not real familiar with the jetronic cars.
Ricardito
Aug 14, 2012 08:29 PM
fess
Mar 29, 2009 03:58 AM
fredbyte
Aug 26, 2008 11:17 PM
beardo265
Sep 27, 2007 09:24 AM
Eric
Jan 19, 2006 08:41 PM
