Uh oh gas leak
Old Aug 13, 2012 | 04:38 PM
nuclearseal's Avatar
Default Uh oh gas leak
Dropped the gas tank to install sending unit.
Filled up today (for second time since the work was done). Leaking gas underneath. I am guessing i probably didnt secure fill pipe correctly? Drove it a few miles to work and seems like it has stopped.
Old Aug 13, 2012 | 08:54 PM
gas leaks aren't anything to mess with. you should get under there ASAP and figure out where it came from, and tighten or fix whatever failed. could be the fill pipe, the carbon canister vent tubing, or the fuel lines, or the seal around the pump/sender assembly access plate.
Old Aug 14, 2012 | 12:19 AM
lev's Avatar
lev
Most likely the Bung Nut is not seated well. When you replaced the sender you left it loose or more likely it did not tread properly.
wildbill
Jul 26, 2009 07:09 AM
1999S80T6
Dec 16, 2008 04:54 AM
dman777
Jan 23, 2008 12:08 AM
jollygoodgold
Jul 16, 2007 12:06 PM
CFGVolvo850
May 11, 2005 04:32 PM
