ignition help igniter falure multible
Old Dec 20, 2011 | 03:23 PM
vercil's Avatar
Default ignition help igniter falure multible
1993 240 keep blowing ignition control moduels, drove the car 6000 miles no probs and then blows igniter put another in and drive a few more k miles and blow another, put another in and started up and blew within minutes, replace again and drive awhile and blows, replace it again and blows after starting it. i changed all components such as ICM crank poss,censer,wireing looks good no corosion at wire junctions. i have had one problem though the tail lights work perfect untill i turn on the head lights and then the brake lights come on but the high light works perfect when i push on the brake with head lights on the high light works as it should but the tail lights are stuck on maybe there could be the issue i dont know
Old Dec 20, 2011 | 04:14 PM
vercil's Avatar
igniter/ ICM/power stage not sure what its called. the module at front inner wheel well drivers side
Old Dec 20, 2011 | 04:44 PM
bubba240's Avatar
I would measure the output voltage of the alternator - a bad regulator causing high voltage might be damaging the ICU.
Old Dec 21, 2011 | 03:07 PM
vercil's Avatar
is this a common thing?
Old Dec 27, 2011 | 12:08 AM
Jason940TSW's Avatar
yes it can be. in all makes i had that happen to my 2003 Dodge Hemi Ram
dodgerkcj
Jul 2, 2018 11:41 AM
Ricardito
Aug 14, 2012 08:29 PM
roytoronto
Apr 26, 2009 10:59 AM
roytoronto
Apr 5, 2009 09:04 AM
