intank fuel pump
Old Mar 13, 2007 | 03:36 PM
loserking86's Avatar
Default intank fuel pump
anyone have some step by steps advice for changing out and replacing the fuelin tank pre pump and filter sock?
Old Mar 13, 2007 | 08:45 PM
JetTech's Avatar
Default RE: intank fuel pump
I don't have step by step but I changed the one in my 91 240. If you have a similiar model then it's as simple as running the tank down to about the quarter mark. Remove the cover plate at the forward left side of your trunk, disconnect the electrical connector, remove the fuel lines at the top of the sending/pickup unit, use a brass drift or screw driver to rotate the lockring counterclockwise. Just tap on the brass drift or screw driver with a hammer while rotating the lockring. Once the lockring is loose remove the whole assembly gently. Take care to gently remove the unit because the float ball can come off as your trying to remove it and that wouldn't be good. Once you have everything out it's just a matter of removing the old pump and install the new one. It will be basic once you get the assembly out and very straight forward.
gamillerman52
Dec 3, 2012 06:34 AM
spidersilva
Aug 17, 2011 07:23 PM
redbottle
Jan 3, 2010 04:14 PM
montysano
Sep 9, 2008 11:52 AM
