Interchangeable ECU?
Old Mar 17, 2010 | 08:59 AM
ramshackle740's Avatar
Default Interchangeable ECU?
I have a 1989 740 Turbo. Quit running in 2007. Replaced Coil, Distributor, Cap, Rotor, Injectors, Fuel Pump, Relays, oxygen sensor. Still does not run. Mechanic thinks it's the ECU. I have an ECU from a 1988 240 - Bosch Jetronic 0280000544 - will this work on my 740 turbo?
Old Mar 18, 2010 | 01:39 PM
bubba240's Avatar
see attached ...
Old Mar 19, 2010 | 01:43 AM
Typhoon's Avatar
Find a mechanic that wants to diagnose the issue, not keep spending your money.
There could be dozens of things producing a no start........."seems to think" is not worth spending money on.
Regards, Andrew.
Old Mar 19, 2010 | 02:07 AM
redbottle's Avatar
let us know if it works...even partially...I wonder if it will short out something?
the 240 gathers info from:
O2 sensor
injectors
idle valve
throttle switch
and other components....
I don't know if the connectors are the same? Do they look the same? ECU COMPARED TO THE OTHER ECU?
If they weren't turbos it would be easier I would think....
Old Mar 19, 2010 | 11:41 AM
adub96's Avatar
That computer won't work, You have an 89 which is a 2.4 and a 544 is a 2.2 ecu... Can you see if you are getting a pulse at the injectors?
templar_just
Aug 30, 2008 10:18 PM
franks70
Jul 19, 2008 07:55 PM
sashapave
Feb 29, 2008 12:06 AM
tipp80
Apr 24, 2006 10:22 PM
Old Red
Oct 5, 2004 10:12 PM
