Intermittent engine start gremlins
Old Nov 24, 2011 | 01:31 PM
Pugluvr's Avatar
Default Intermittent engine start gremlins
1990 240DL Wagon
154k miles
I have an intermittent issue upon engine start and would like to begin the hunt for the possible cause(s).
The symptoms that have me concerned are:
#1) Occassionally - when I turn the ignition key to start the engine, there is a brief pause before the starter engages. The normal for this car is for immediate engagement of starter.
#2) Occassionally - when I turn the ignition key to start the engine, the starter immediately engages but it cranks slower than normal - like starting a car with a weak battery or in very cold, cold temperatures.
The battery is a two month old AutoCraft with 600 cold cracking amps. Several times I have checked the battery voltage after the car has sat for two days and both times it was at 12.5 volts. I have checked the alternator by checking the voltage at the battery after startup and I am getting 14 volts.
Any suggestions on what I should look at for possible causes?
Old Nov 24, 2011 | 05:45 PM
lev's Avatar
lev
You may have a bad ignition switch.
Old Nov 24, 2011 | 07:40 PM
Pugluvr's Avatar
I can picture where a bad switch might be the reason for the pause (e.g. worn contacts) but how would that cause the slow crank?
Old Nov 25, 2011 | 02:33 PM
lev's Avatar
lev
Good point! Starter may be getting weak, another possibility...
'82CO244
Jan 7, 2015 10:40 PM
Sofar.
Apr 11, 2009 04:01 AM
VolvoDriver
Aug 17, 2007 11:08 PM
profcharlie
Jan 19, 2007 12:08 AM
850GLT
Sep 8, 2005 01:07 PM
