Loud clicking sound from 1994 940 engine
Old Jun 12, 2011 | 09:27 PM
katman104's Avatar
Default Loud clicking sound from 1994 940 engine
Guys,
I was traveling this past weekend from Ill. to MS and before I left on the trip I checked oil level, transmission oil level, water level and everything was within limits. Had driven about 300 miles and had to slow down to merge with traffic while changing to a different highway. Upon accelerating at a normal level noticed a loud clicking from the engine I thought. Pulled over to exit and check this out and discovered that at idle speed no noise from engine. Gave it a little throttle and noticed a pretty noisy clicking and clanking from the engine compartment. I had no lights on the instrument panel and water temp was normal.
Had to stay overnight and got family member to bring my dually and trailer to me and we loaded it on trailer and brought it home.
Anyone have any ideas on how to trouble shoot this to find out where the noise is coming from? This is a non-turbo engine.
Any suggestions appreciated katman104
Old Jun 16, 2011 | 06:58 AM
katman104's Avatar
Hey guys,
Am I the only one with a 1994 940 Volvo sedan? Has no one encountered a clattering sound from their 2.3L engine? I need some help here on what to do to isolate whether it is a rod, timing belt slipped a notch, might be an exhaust leak, whatever it might be. It has no miss in engine, no loss of power and still would shift fine when I shut the engine down last Friday. I have not started it since.I will try something if someone has a suggestion. Any help greatly appreciated.
Katman104
Old Jun 16, 2011 | 09:00 AM
lev's Avatar
lev
Hard to diagnose a noise you can't hear... If you have no noise at idle but noise at higher speed, this sounds like an oil starvation problem, internal, may be rod knock... How many miles on this motor? Oil service history? These motors are great but they do throw rods now and then... Exhaust leaks sound different than a mechanical clanking, and it will usually be louder when cold.
Old Jun 16, 2011 | 11:32 AM
swiftjustice44's Avatar
If you're able, the best thing to do would be to post a video with sound. From a description alone, it could be anything from bad valve hushers to a conn rod valiantly struggling to escape the dark confines of the engine block.
Old Jun 17, 2011 | 04:38 PM
katman104's Avatar
Thanks for answering...The motor has 126000 miles on it and it has been serviced faithfully. I had been on the road for about 7 hours when this started
and I hauled it home on a trailer. Guess I will carry it on to the volvo shop as bad as I hate to. Can't put to much into it because resale is not that much. Timing belt was replaced at 100K miles by volvo dealer.
Katman104
Old Jun 17, 2011 | 04:41 PM
katman104's Avatar
Thanks for your response...
Will try to make a video with sound and post on U-Tube. Will post if I get this done.
Katman104
Old Jun 17, 2011 | 04:52 PM
ed7's Avatar
ed7
Clacks come from the top end and raps come from the bottom end. A screw driver or length of hose to ear to engine may help locate the source of the noise.
The rod bearings are not easily accessible on this one.
Check oil pressure with a gauge.
Ed
Old Jun 17, 2011 | 08:55 PM
Originally Posted by katman104
........ Guess I will carry it on to the volvo shop as bad as I hate to. Can't put to much into it because resale is not that much. Timing belt was replaced at 100K miles by volvo dealer.
Katman104
It's always a good idea to keep a record of expenses; it's the only thing that will ever push me towards letting one of my flock go. All my Volvos have more money in them than market value (particularly when sweat equity is factored in). People who lack the ability, inclination or time to work on their old Volvos probably need to let them go. Paying shop labor rates on a regular basis is just crazy.
Old Jun 17, 2011 | 11:09 PM
zloetakoe's Avatar
Amen to that. That's why I'm driving 2 Volvos around. For the most part they let me work on them without too much hassle.
Old Jun 19, 2011 | 05:50 AM
katman104's Avatar
Hey Guys,
My son got home from summer camp and investigated the noise and it is a exhaust leak on the back exhaust port.Seems the gasket has sprung a bad leak.Anything in particular we should know before we undertake putting exhaust manifold gaskets on? Thanks for all the help. I am sure glad we do not have to go into the engine.
Katman104
Old Jun 26, 2011 | 03:58 PM
katman104's Avatar
To all,
Replaced all exhaust gaskets on manifold and this cleared clicking sound up. I just had one gasket, the rear one on passenger side that had blown out a chunk but replaced all since had to remove the manifold and clean all surface areas.Replaced with the Victor Reinz gasket set. It sure is good to have a son that does mechanic work. Glad to have the Volvo back in working condition because it is a beautiful driving vehicle. Thanks to all for the assistance through the forum. An administrator can close this post whenever you like.
Katman104
Old Jun 26, 2011 | 08:13 PM
my 92 745T did much the same thing last week, and in my case, its apparently a blown head gasket between #3 and #4 (compression is down on both of those, and they apparently are sharing some compression). Mechanic is taking the head off next week, so we'll know more.
there's no coolant in the oil or oil in the coolant, which is what has happened both other times I've had a blown gasket.
Baffled
1998-2000 model year V70
Aug 29, 2013 04:57 AM
LOVEvolvos
Apr 24, 2012 10:36 PM
fredbyte
Jul 22, 2008 04:21 PM
NA850ESTATE
Mar 13, 2008 08:36 AM
danrashba
Jul 27, 2005 10:06 PM
