MAF sensor
Hello !
May be you can help me ?
I have some problems with Volvo 740. 1988, 2.3 L, B230E start. The engine was worked on idle speed 5 seconds then did not work. By pressing accselerator the engine ceased to work at once. After switching-off MAF sensor, the engine idle speed 750 rpm ( on cold engine), by sharp pressing a gas pedal ceases to work. Is it means problems with MAF and how I can check MAF sensor ?
