In the middle of a timing belt change and . . .
Old Nov 6, 2010 | 03:51 PM
darkdelta's Avatar
Default In the middle of a timing belt change and . . .
1990 245 B230F
I noticed there is a slot for a keeper on the crankshaft pulley the one with the accessories are driven from there was no keeper on this pulley. The pulley for the timing belt does have a keeper. I noticed what looked like some marks where the shaft may have turned inside the pulley. I have looked everywhere and can not find where it. if it was there to begin with. I used an impact wrench to loosen the 24 mm bolt and it really had to work on it to get it loose. I hope to finish this today but it is looking doubtful. Any help is appreciated.
Old Nov 6, 2010 | 04:39 PM
ed7's Avatar
ed7
The belt sprocket on the crank should be keyed. If the key (which is cast into) is broken, there is no completion until you get a new sprocket.. There is no way to index the belt otherwise.
Washers on either side if the sprocket flair away from the belt.
ED7
Old Nov 6, 2010 | 09:50 PM
darkdelta's Avatar
Default Thanks
Well, paraphrasing Walt Kelly's comic strip character I have met the enemy and it is me!
ED7, Thanks for setting me straight, hopefully I can finish Sunday.
aoffredi@yahoo.com
May 3, 2009 11:01 AM
windhamearle
Feb 8, 2009 09:06 PM
spunkymonky
Oct 11, 2008 06:41 PM
chopsieze
Sep 8, 2008 02:27 PM
nationm
Feb 12, 2006 10:09 PM
