In the middle of timing belt change
Old Oct 10, 2008 | 09:17 PM
spunkymonky's Avatar
Default In the middle of timing belt change
I'm in the middle of doing the timing belt but don't want to continue until I'm 100% sure about something. I cannot see the crankshaft mark. I've gone round and round and round and I just don't see it. Will I be taking a chance removing the belt when just the camshaft marks are lined up? Also do they make volvo stamped belts still? Just curious if this is the original belt.
Old Oct 10, 2008 | 10:03 PM
Default RE: In the middle of timing belt change
Did you remove the lower serpentine pulley?
If not then the mark will be really hard to see.
Yes if it is the OEM belt it should say Volvo.
Old Oct 11, 2008 | 06:41 PM
bcon415's Avatar
Sorry to be so late responding. I recommend that you read http://volvospeed.com/Repair/s40_timing_belt.html, it's an S40 but real similar. Also, you might read the posts where I have had so much trouble with timing this engine. You might have already seen and read them, but if not, here is the link: http://volvospeed.com/vs_forum/index...;#entry1393157
darkdelta
Nov 6, 2010 09:50 PM
aoffredi@yahoo.com
May 3, 2009 11:01 AM
windhamearle
Feb 8, 2009 09:06 PM
meganc731
Mar 5, 2008 05:40 AM
nationm
Feb 12, 2006 10:09 PM
