Multiple ECU Codes
Old Jun 15, 2022 | 09:07 PM
shwebo's Avatar
Default Multiple ECU Codes
A while back, got a MAF code...
Replaced the MAF. No, not a Bosch unit... couldnt find one.
After some reviews I bought a new part from Delphi
Code went away... drove fine.
Today, light comes on again... but this time I have 3 codes.
1-1-3 Lambda Control- Engine running to lean/rich
2-3-1 Lambda Control- Too lean or rich at part load
3-2-2 MAF Burn-off signal missing or faulty
So, pretty rough idle, especially when cold, but even when warmed up it lopes pretty noticeably.
Otherwise drives fine.
What am I looking at? What is the difference between the two Lambda codes? .... seems redundant
Old Jun 16, 2022 | 08:32 AM
there's different fault codes for fuel trim by engine speed - ie is the O2 sensor reading out of the expected range at idle? is it reading out of range at part or full throttle? The nuance here is at idle a small vaccuum leak can lean out an idle but its too small to impact the trim with the throttle open.
I'd be focusing on the 322. Here's some light reading:
https://www.brickboard.com/RWD/volvo..._322_code.html
Old Jun 16, 2022 | 10:22 PM
lev's Avatar
lev
From practical experience, the MAFS is the likely cause of all those codes. Getting a good one has become a challenge.
masoug
Feb 20, 2020 09:57 AM
1995Volvo850
Oct 28, 2013 06:50 AM
schwalbe181
Jul 12, 2010 01:53 PM
cmstar
Jun 9, 2010 01:40 PM
seala8
Jan 4, 2009 01:48 PM
