My 1990 740 Leaks ATF Badly
Old Oct 5, 2016 | 03:47 PM
DP Farrell's Avatar
Exclamation My 1990 740 Leaks ATF Badly
My 1990 740 goes through about a quart of ATF every 2 days. I'm not sure what it is called but the Aluminum tube that runs from the ATF dip stick down to the Transmission has a crack in it, I can see the drips start at the bottom of the bend when I pour in the ATF. What is the name of that tube, and where can I get one? What other advice can you give me re: leakage of ATF? Thank you.
Old Oct 5, 2016 | 04:00 PM
Nichals's Avatar
the Transmission dipstick tube or fill tube
Pretty easy to replace, odd that it cracked however, perhaps its simply loose?
new they are between $40-$60
Used $5-$20
Old Oct 5, 2016 | 05:43 PM
DP Farrell's Avatar
Thanks, Nichas!
Old Oct 5, 2016 | 05:44 PM
DP Farrell's Avatar
Thanks, Nichas.
bowlerhat
Apr 4, 2010 09:37 PM
stjuuv
Mar 9, 2010 03:53 PM
AzNick
Jul 2, 2009 08:44 PM
740GLWagon
May 3, 2009 10:06 AM
daver
Nov 23, 2008 09:17 AM
