My new(old)93 940t wagon
Old Jan 2, 2007 | 10:23 PM
lotusing's Avatar
Default My new(old)93 940t wagon
Well I purchased a 93 940 turbo wagon without knowing any history on the car.It has 126k and the first thing I did was timing belt,all seals and belts. The car checked out to be very well maintained.The question I have is should I just change the trans fluid and screenor should I flush it?.It does look clean and red with no burning smell.What is the best trans oil being that I will towing a small boat this summer.Should I change the diff oil and again what oil should I use?
Thanks
Old Jan 2, 2007 | 10:42 PM
Default RE: My new(old)93 940t wagon
Pull the drain plug and refill.
Old Jan 3, 2007 | 12:29 AM
lotusing's Avatar
What oil do you recomend trans/diff? You do not think that I shouldchange the screen?
Old Jan 3, 2007 | 08:58 PM
Trans regular ATF
Rear 80 or 90 gear oil
I have never changed the screen you can if you want to.
The dipstick tube is usually really hard to get loose.
Old Jan 4, 2007 | 02:17 PM
lotusing's Avatar
I was going to use red line gear oil because I have had great luck with my other cars.I guess it is over kill for this car.
Thanks again Tech!
donf
Jul 5, 2013 02:52 PM
Red Tractors
Sep 18, 2012 01:38 PM
sdguy
Apr 20, 2010 10:08 PM
lotusing
Dec 31, 2006 10:59 PM
evyllp
Nov 30, 2004 09:58 PM
