Mystery Humming Noise..
Old Oct 3, 2010 | 09:11 PM
schwalbe181's Avatar
Default Mystery Humming Noise..
Before I begin, Let me give you alittle update. Car still needs a full tune, plugs, wires, air filter, oil change, what not. I plan on doing alittle modding, as far as new air intake system and then cat delete. Im doing the oil change and sparks soon. But im not sure if any of that delay of things may be causing this.
Just recently ive noticed a whine that sounds familiar to powersteering whine when the car is in drive, and usually dips away once the motor is above 1000 rpms. However, at idle, it is very pronounced and not coming from any typical spots, ie, fuel pump, power steering. But at idle, if i put it into N it stops. The whine goes away, but as soon as i bring it back into gear, it whines again. Only does it after ive been driving for a few minutes, not right at start up fresh. Any suggestions as to what im looking at deal with?
fritzlovesmary
Mar 10, 2011 09:52 AM
ryan314
Jul 14, 2007 06:03 PM
SloptownRat
Jun 4, 2007 04:30 AM
s80t6schcik
Mar 22, 2007 03:57 PM
SlavaD
Jul 31, 2006 11:56 PM
