93 240 valve adjustment tool advice.
Old Oct 3, 2010 | 12:28 AM
Hookem's Avatar
Default 93 240 valve adjustment tool advice.
Made a typo it is a 1993 240.
I know the search function is your friend but I have been unable to find out which tool is the preffered tool and where to purchase one.
I found a thread where a company will rent you a box with the shims and tool for 60 dollars but would like to just buy the tool. 24,000 miles comes around quick in Houston.
I have found several threads about changing the timing belt and seals but not much on valve adjustment procedure and the tools needed.
Thanks for any advice.
Old Oct 3, 2010 | 03:29 AM
TIPSP's Avatar
Got Boost?
If you don't return the tool you rent from ipd, it is yours for that $60 deposit. That is the tool I used when did the adjustment on the 740. Works pretty good. And a set of picks to get the shims out.
Old Oct 3, 2010 | 11:14 AM
Hookem's Avatar
Do they send you the tool and shims or just the tool and picks ???
I found this tool. http://www.ipdusa.com/version.asp?st...ID=0&V_ID=6637
I talked to a freind last night that told me someone sells a tool that has two different ends that works on a bunch of different cars with the bucket and shim setups.
And last but not least how much are the shims from Volvo ???
Thank you for the reply TIPSI.
Old Oct 3, 2010 | 02:21 PM
TIPSP's Avatar
Got Boost?
Okay... So the tool is $35.00. Cool cheaper than I though.
I used the shims that ipd sent with the kit, and bought some picks. I don't know how much or if Volvo sells the shims. Some people go to the junkyards and remove as many shims as they can get and then measure the thickness with calipers.
fcpgroton.com should have shims like ipd does.
Old Oct 3, 2010 | 03:14 PM
Hookem's Avatar
Can you just outright buy the tool and shims for 60.00 bucks ???
Old Oct 3, 2010 | 10:04 PM
TIPSP's Avatar
Got Boost?
I am not 100% sure. Call them up tomorrow, and see what they can do.
DCampion
Nov 20, 2010 07:19 AM
nextproject
Nov 16, 2009 07:04 PM
dsniner
Dec 23, 2007 12:12 AM
v62cobra
Jul 28, 2006 02:00 PM
browntrout
Jul 2, 2006 10:52 AM
