Need brake light help PLEASE!
Old Feb 28, 2010 | 04:51 PM
Beemer2002's Avatar
Default Need brake light help PLEASE!
I have a gremlin- When I have my headlights off, all three brake lights light up properly. When I have the headlights on, the drivers side goes black and does not light up at all when my light are on.
I have take the bulb out and sanded the contact points, to no avail. Any suggestions are greatly appreciated!
Old Mar 3, 2010 | 09:02 AM
cbevis's Avatar
sounds like you either have a short or two in the tail light wiring harness or a bad relay/switch. The wires are all color coded....start looking around for busted wire. Beyond that, start testing your switches with a multimeter.
Old Mar 6, 2010 | 02:19 AM
Typhoon's Avatar
Replace driver's side bulb. Sometimes the filaments short together.
Regards, Andrew.
Old Mar 6, 2010 | 06:57 PM
Beemer2002's Avatar
THANKS- turns out to be the socket- I took the bulb out, popped it back in and it worked- hit a hard bump and bad again- I can't seem to keep the bulb tight.
Old Mar 21, 2010 | 10:33 PM
iatotofts's Avatar
You shut be able to kinda bend the prongs up on the socket.. which will keep snug when you screw the bulb back in
Cheers mate
Old Mar 21, 2010 | 10:34 PM
iatotofts's Avatar
Cheers mate
Should***
MNWILD
Sep 10, 2020 11:29 AM
BRAD L
Jan 26, 2013 06:16 PM
mowntnbkr
Aug 27, 2011 10:07 PM
Sanel30
Feb 18, 2010 09:16 PM
Armenian
Jul 20, 2009 12:02 AM
