Need help finding out whats wrong
Old Dec 5, 2010 | 04:29 PM
goodboyz358's Avatar
Default Need help finding out whats wrong
so i have a 1991 volvo 740 turbo with say 195,etc mils on it i have been having problem lately with it i have lose of power you start it up it runs normal but when you get on the gas it back fires and misfires and has trouble getting up to high rpms inorder to get up to high rpms you can hit the gas rapdle and it will slowly began to gain rpms but it still runs rough im not for sure whats wrong with it tho i have noticed that i have smoke coming from the dipstick its ex gases coming from it what could this be since the not a fuel problem because it has a new fuel filter and new fuel pumps also has new spark plugs and wires has a new tp senor and i did a compresstion test all 4 cyc showed 150psi what is wrong with this engine i need to know because this is my means of tranption in a couple of weeks
Old Dec 6, 2010 | 11:22 AM
coonmanxyz's Avatar
That is the longest sentence I have ever read. Punctuation?
Timing?
Old Dec 7, 2010 | 12:34 PM
ltrail's Avatar
+1 on timing. My 240 recently had this issue. Was off a tooth. Poor acceleration, milage, etc. The other thing is possibly the lift pump on the tank. If its slowing down it wont her enough fuel. If it dies completely the car wont run. Last check the main relay. I recently had a 240 in and he said it just won't run like it did.the solder around one of the pins rattled and cracked. Made poor connection and didn't her enough fuel to run smmooth. A dab of solder fixes it up nice.
Old Dec 7, 2010 | 01:40 PM
ed7's Avatar
ed7
Cap and rotor/ wires/ plugs need to be checked. Fer shure, timing's buggin'.
Ed
goodboyz358
Dec 5, 2010 09:40 PM
big alan
Mar 15, 2010 02:21 AM
danadornburgh
Feb 20, 2009 09:23 PM
alsawye
Dec 16, 2008 05:00 PM
T5RACER
Nov 3, 2006 04:57 AM
