Need help - No OD?
Old Feb 10, 2011 | 12:33 PM
sbraatz's Avatar
Default Need help - No OD?
New to the volvo postings and I need the help of the experts. Yesterday, the OD dropped out (I think). I was driving normally at first then the tach went to 3700 rpm and thinking I bumped the OP switch, pushed it and no change. Is it possible the OD relay has gone out? What other areas should I be looking at?- I've experienced similar symptoms in the past with my 245, but never on the 740T. Currently have 267K on the engine, new head gasket w/machined head, new sway bars and end links, turbo plus kit, K/N filter. Always been a strong runner and hope to keep it for a bit longer. Any help is appreciated. Thanks, Skip
Old Feb 10, 2011 | 12:48 PM
Titan Joe's Avatar
Is it an auto or stick? Year is also a good thing to post too.
The relay is a good place to start. It could be the solenoid too. In the manual, the wiring can chaff until it doesn't work. Also low fluid in the manual OD can make it not work. I only really know things about the manual OD, so if it's an auto, someone else will be able to offer some help.
Old Feb 10, 2011 | 12:51 PM
sbraatz's Avatar
Sorry for leaving out some of the important stuff. 1991 740T, w/auto trans.
andrei3333
Dec 26, 2010 10:22 AM
Sanel30
Feb 18, 2010 09:16 PM
texan_176
Oct 4, 2009 10:05 PM
chef
May 19, 2009 05:57 AM
Svtfiveoh
Apr 15, 2008 06:51 PM
