Need manual transmission
Old May 10, 2025 | 10:55 PM
joshyoder's Avatar
Default Need manual transmission
I need a manual transmission for my '92 240. does anyone have a lead on a good used unit? I'm located in southern kansas. I pulled the transmission out today, hoping the grinding noise was just a bad bearing. There's teeth broken off a gear.
Old May 11, 2025 | 01:48 AM
4 speed + OD or 5 Speed?
You could try Voluparts.com in Atlanta 404-352 3402
Old May 11, 2025 | 08:51 AM
joshyoder's Avatar
It's the 5 speed.
Old May 11, 2025 | 02:13 PM
joshyoder's Avatar
Thanks for the suggestion. They replied that they don't have the M47 transmission. I'm learnign that these trannys are kind of rare, and not very reliable. If I can't find one, I might consoder a T5 conversion. I used to drive a volvo with the M46, electronic overdrive. I liked it ok. I see several of those on Ebay, I might just go that route. Can anyone tell me if the M46 will bolt to my bell-housing? It has the notch for the crankshaft sensor.
Old May 13, 2025 | 12:18 PM
try car-part.com its a national used car part (recycle yard) search engine. You can also try Craigs List or Ebay to see if somebody is parting out a car.
Old Feb 28, 2026 | 05:28 AM
renardanderson2's Avatar
Old Feb 28, 2026 | 05:47 AM
Golden redblock's Avatar
Default Tranny
Check with
L&D Volvo Redblock parts
Atlanta Craigslist
They are completely independent
Peter Savnik
Penta
Apr 3, 2020 01:31 PM
hosedagain
Apr 13, 2014 08:48 PM
1995Volvo850
May 12, 2012 09:15 PM
michaelmorris
Jan 24, 2006 10:52 AM
