Newbie Needs to Flush the Coolant of his 89 740Turbo Wagon
Hey all I'm a total car novice. I have a recently purchased 1989 740 Turbo wagon that I want to but that engine sealer stuff into. To do that I have to drain the coolant system and then follow the directions that came with the engine sealer.
Can anyone point me to some simple instructions on how to do this?
Much appreciated!
Much appreciated!
Why are you a sealant product? What is it exactly? I am usually suspicious of wonder products.
there is usually a plastic plug some place on the bottom the the radiator. I believe on my 940 (very similar car) it could be opened with a screw driver. This should drain roughly half the fluid. the other half will still be in the engine block itself. When flushing fluid, I usually just keep adding water till it drains out clear, then drain whats in the radiator and add straight coolant.
And if you have any more questons, this is a great place to look. http://www.swedishbricks.net/700900FAQ/FAQSummary1.html
Here are some more specific posts for your problem.....
http://www.swedishbricks.net/700900F...gine%20Coolant
BuzzBrick
Apr 19, 2011 11:11 PM
xmoke
Oct 17, 2005 02:31 AM
