No Brake Lights
Old Sep 22, 2005 | 04:29 PM
gorogergo's Avatar
Default No Brake Lights
I recently bought my first Volvo, a 1989 240 DL wagon. While I enjoy it, I no longer have brake lights.
I have used a multi-meter to test the bulbs, fuse, and switch. I have determined that I have 12V exiting the switch. Is there a common point or item in between the switch and the bulbs that I should be checking before I really tear into it?
Thanks for the help, I love this site.
Old Sep 22, 2005 | 07:32 PM
matthewensey's Avatar
Default RE: No Brake Lights
Give me your email address and I'll send you the wiring diagrams for my car, 88 240. Should be close at least.
Old Sep 22, 2005 | 10:17 PM
The printed circuit board on the taillight goes bad.
Old Sep 22, 2005 | 11:39 PM
gorogergo's Avatar
Would that cause them all to go out?
About a week ago they all worked.
Old Sep 23, 2005 | 08:24 PM
AGE!!!!
Do they have any water in them?
Old Sep 25, 2005 | 02:27 AM
gorogergo's Avatar
Had a little time to look at them today. No signs of water. I have power exiting the bulb failure sensor, but not at the brake lights. Will spend some time tomorrow removing interior parts and examining wires. If I don't see any obvious damage at that point, I will just run new ones all the way back.
Old Sep 25, 2005 | 11:24 PM
Ok keep me posted.
Old Sep 28, 2005 | 07:37 AM
vinnievolvo's Avatar
I had the same problem recently with my '90 240 sedan. Solution was to replace brake light switch located under the dash near brake pedal. Caution! There are 2 switches, one is easy to reach, but the other is really hard to access. I gave up and took it to my mechanic to have it replaced because of course the faulty one was the upper switch.[:@]
Old Sep 29, 2005 | 11:15 PM
gorogergo's Avatar
Re-checked everything tonight. I have an intermitant problem with the brake switch. Not many things worse than an electrical problem that comes and goes. Tomorrow a new switch goes in.
A big "Thank You!" to all of you who helped so much.
Of course now I have a new problem.
Old Sep 30, 2005 | 10:11 PM
gorogergo's Avatar
Switch changed out. All is good.
Thanks again everyone.
aznyaz
Jan 9, 2015 02:38 PM
zinko
2001-2013 model year V70
Feb 11, 2014 07:18 AM
Scott V
Jul 21, 2013 02:28 PM
Mellott
Jun 13, 2011 11:41 PM
chrystald423
Mar 27, 2010 08:05 AM
