no fire
Old Dec 15, 2009 | 05:06 PM
gtimansc's Avatar
Default no fire
hey guys i just bought a 94 940 with the 2.3 and when i got it the guy said the fuel pump was bad i put a battery in it and tried to crank it it took a lil bit but it started but run rough then i let it run for a few mins with me giving it gas then it just shut off i tried to crank it and it wont start i pulled the fuel line off its getting good fuel up to the rail i kept messing with it and got it started the next day but did the same thing now it wont start at all and i check the plugs and no fire but i have juice to the coil can the coil still be bad or could it be something diffrent it has a new cap rotor button wires and plugs any help is appriciated thanks
Old Dec 16, 2009 | 03:20 AM
Typhoon's Avatar
Pull codes from teh car. And suspect crank angle sensor.
Regards, Andrew.
Old Dec 16, 2009 | 09:12 AM
gtimansc's Avatar
ok i done the jumper wire under the hood with the red led light and it came up 1-1-1 and from this site its says no faults could the ignition control module be bad?
Old Dec 16, 2009 | 03:56 PM
fredbyte's Avatar
No spark means mainly 3 things: bad coil, bad Power Stage, or bad RPM sensor. Oh, another thing could be wiring issues, such as broken wire or short circuit. Go to www.stepbystepvolvo.com for free guide to 740 no-starts. May help you some on 940.
POKDUB
Oct 3, 2005 11:20 AM
dewrat
Aug 21, 2005 01:18 PM
azmark
Jul 21, 2005 11:39 PM
petesbween
Mar 6, 2005 01:33 AM
waxk
Feb 9, 2004 11:46 PM
