no heat! 940
Old Jan 2, 2006 | 01:34 PM
twofourdee's Avatar
Default no heat! 940
95 940, changed heater core everthing works proper except no heat. both heater hose's are hot going in and out of the core at fire wall, just wondering maybe thermostate, or climate control cold to hot switch isn't fuctioning correctly. if i turn the switch from cold to hot there is hardly any sound of anything happening while the car is running at normal temp.maybe the air vacume lines are wrong, but they seem to be ok floor,def,vents all the air comes out where you want it to. any idea's!
Old Jan 2, 2006 | 09:07 PM
Default RE: no heat! 940
You need to try checking for vaccum at the heat valve in the dash. Other than that it is hard to say without seeing it.
Old Jan 3, 2006 | 11:32 PM
twofourdee's Avatar
that has to be the problem the thermostat seems to be good. I'm waiting for some shop time i live up here in canada can't stand the cold... need heat!
Old Jan 18, 2006 | 11:17 AM
twofourdee's Avatar
Got heat! forgot to plug in the green connector near the trap door.
Old Nov 20, 2024 | 07:01 AM
94'945's Avatar
Sorry to resurrect a dead thread but I have the same issue and I NEED to know what green plug and what trap door. Please please I need heat🙏🏼
danmac75
Nov 9, 2007 06:12 PM
danmac75
Nov 8, 2007 11:51 PM
Evren
Dec 21, 2004 11:11 PM
oldbug
Dec 17, 2004 10:46 AM
funsox1
Jun 10, 2004 02:45 AM
