No Start 940
Old Aug 5, 2011 | 02:09 PM
rosicler's Avatar
Default No Start 940
i have 1991 turbo 940se and the speed control is not working. what is basically the problem and what relay do i have to replace if needed. Thanks
Old Aug 5, 2011 | 04:14 PM
no start? or no cruise control? thats two entirely different issues.
cruise control is not just a relay, its a fairly complex system where the cruise control stalk, the speedometer, a whole pile of sensors and switches are connected to the cruise control module, there's a vacuum booster, and the vacuum modulator that pulls on the throttle pulley under the hood.... _any_ of these things can cause it to malfunction. first thing I'd check would be the vacuum lines.
Old Aug 8, 2011 | 11:35 PM
rosicler's Avatar
Default Speed Cruise Control
Hi Pierce - My Garage !
I am sure glad to be a member of this Volvo Forum because due to your advice I was able to fix the problem on my cruise control. Yes the culprit is the vacuum line which is connected to the intake manifold. I am also replacing the other lines which are old and hardened. Again thanks for the advice. cheers!
Rosicler
partyboat1
Apr 26, 2012 04:32 AM
ogotaj
Mar 22, 2008 02:57 AM
pitttl
Nov 15, 2005 10:23 AM
broncodw
Jun 29, 2004 11:54 PM
Glen
Oct 24, 2003 09:56 PM
