noise after an oil change
Old Nov 5, 2013 | 12:31 PM
drummerzyto's Avatar
Default noise after an oil change
hi, like i mentioned on another tread i bougth a 1984 240 dl recently, so in order to start a maintenance routine on it, i change the oil, oil filter, air filter, new sparks and wires. but after the oil change, the engine starts to make a noice. seem to be the lifters but im not sure. I use 10w-30w oil. Any suggestion about the sound?? thanks again for the help!!!
Old Nov 5, 2013 | 11:20 PM
verify you put enough oil in it.
I suppose its possible the engine is very tired and worn out and has 'piston slap' and/or valve clearance problems, and the previous owner put heavy weight oil in it to quiet it down. the good news is, they will run for years with a bit of piston slap. if it IS valve lifter noise, the valve clearance should be checked and shimmed if neccessary.
Old Nov 6, 2013 | 11:59 AM
sicnarf's Avatar
Change your oil to 10w40,its a little thicker.
Old Nov 7, 2013 | 07:46 AM
jagtoes's Avatar
I started to get piston slap around 175K miles and now have 336K with the same noise. It sounds like a quiet diesel when idling and hasn't been a performance issue.
Old Nov 7, 2013 | 10:51 AM
i used 5 quarts, thanks for the info!!
Old Nov 7, 2013 | 10:53 AM
ok thanks ,, i will try it , on the next oil change!!
Old Nov 7, 2013 | 10:54 AM
the use of metal lube is safe??
Old Nov 7, 2013 | 11:53 AM
hmm? not sure what you're asking about.
Old Nov 7, 2013 | 12:19 PM
its about the antifriction
engine treatment metal lube
Old Nov 7, 2013 | 12:44 PM
thats an oil additive? I've never liked using any of those, any proper engine oil has all the additives it needs.
oil *IS* antifriction.
Old Nov 7, 2013 | 02:17 PM
thanks so much for the tip,!!
here the address,, for the product Home
Dfisher85
Sep 15, 2014 02:08 AM
mcl5126
Sep 8, 2010 09:11 AM
oldvovo
Jul 3, 2008 06:34 PM
NCS60
Apr 5, 2007 12:53 AM
