Car is dying after oil change
Old Jul 1, 2008 | 11:40 AM
oldvovo's Avatar
Default Car is dying after oil change
Greetings,
My 96 850 turbo (wagon) recentlyhad an oil change. I had to have a shop do the change b/c the drain plug was frozen (from previous owner) in to the oil pan. The oil that came out of the car was 10/30 regular oil, replace w/ 10/30 synthetic, along w/ a new oil filter (OEM). The car drove fine on the way home ~10 miles on the freeway & ~5mi through the city and was parked for 2 days. Yesterday I got in my car and drove it to the gas station to fill up , tank was very low - (miles to zero was under 30). After filling up the car died about 1 mile later down the road and would not restart, let it sit for about a minute and it started up fine - then died again about 1-2 minutes later. This kept happening all the way home, it would die and sit for ~30 seconds and then start right up again. [:@] All the dash lights would come on when the car dies.
Car has ~62k miles.
Any ideas?
oldvovo.
Old Jul 1, 2008 | 11:58 AM
axelm's Avatar
Default RE: Car is dying after oil change
Bad fuel? Bad fuel pump? Driving without fuel in the tank is not good for the pump since the fuel is used to cool it. The pump might have been close to EOL (end of life) and the last overheating just killed it. Just some wild guessing.
Old Jul 1, 2008 | 12:05 PM
oldvovo's Avatar
Is 60,000 miles close to the normal life of an 850 fuel pump?
Old Jul 1, 2008 | 12:43 PM
axelm's Avatar
60K does not sound like a lot.
Old Jul 1, 2008 | 12:47 PM
Eric J's Avatar
But the age ofit does have something to say. The pump is suspect.Changing the fuel filter will help also.
Old Jul 1, 2008 | 01:06 PM
axelm's Avatar
Isn't there a way to measure the PSI at the fuel rail? Changing the pump just in case isn't exactly cheap
Old Jul 1, 2008 | 07:32 PM
axelm's Avatar
I used to work for a gasoline pump manufacturer. Water in an underground storage tank could do that to your car. You could try and go to the fuelling station and ask them to print out a alarm history report from the Veeder Root tank gauging system and see if they had a high water alarm in the tank.
Old Jul 1, 2008 | 09:52 PM
oldvovo's Avatar
ORIGINAL: axelm
worth a shot - it was running normal until I filled it up....
Thanks.
Old Jul 1, 2008 | 10:32 PM
info2x's Avatar
ORIGINAL: axelm
There is a schrader valve on the end of the fuel rail near the throttle body.
Does the car do anything before it dies aka cough and sputter?
Old Jul 2, 2008 | 08:33 AM
Psaboic's Avatar
Could also be that the crud in the bottom of the tank was stirred up by filling it after it was so low, and the crud kep getting sucked into the filter. As I always say, start with the easy stuff first....change the fuel filter and see what happens
Old Jul 2, 2008 | 10:44 AM
Quick Brick's Avatar
I, too, was going to suggest a fuel issue.
I recall letting The Anvil run dry, ONCE, and for about two weeks he would run rough, stall at stop lights, or just chug and bang and knock as I pulled away causing some weird looks (anger to giggles)from other drivers. Hated [sm=smiley7.gif]that.
It turned out to be air in the line and finally cleared up one day.
Have not let thetrip computer show below the 100klms left since then as I rather not go through that again.
Can aguage be added inline to monitor preasure? If anything, guages under the hood look kinda cool [sm=smokin.gif]
I hope that you can solve this as no time is a good time for this to happen, especially during the summer []. And 60k is way too low for this type of failure. I have over three hundred and sixteen kilometers on mine and no problems, unless I let it run out again
[sm=icon_cheers.gif]
Old Jul 2, 2008 | 02:03 PM
oldvovo's Avatar
Thanks for the suggestions everyone.
A neighbor (who has owned an 850 in the past) said this happened to him once and it turned out he didn't tighten down the gas cap enough... does that make sense? < I'll try that , then check fuel pressure and move onto the filter and pump if I have to.
Old Jul 2, 2008 | 11:26 PM
axelm's Avatar
That would trigger a CEL but I don't know if it would cause the car to malfunction.
Old Jul 3, 2008 | 08:39 AM
Psaboic's Avatar
Yep, I would believe it would cause the CEL, but not lousy performance. It does sound like a fuel issue though
Old Jul 3, 2008 | 11:06 AM
oldvovo's Avatar
Just for the future... what is 'CEL' ?
Old Jul 3, 2008 | 06:34 PM
ORIGINAL: oldvovo
Cheeck engine light.
Allenkkim1994
Mar 20, 2013 11:43 PM
jon9851
Nov 21, 2008 08:26 PM
youngvolvoowner
Aug 31, 2008 10:28 PM
davidmhuber
Aug 20, 2008 12:22 AM
NCS60
Apr 5, 2007 12:53 AM
