now where?
Old Apr 11, 2005 | 06:51 PM
wavewright's Avatar
Default now where?
ok, now when i start the car it wants to stall and does for about 2min. does the reving idle thing. once it warms up it will idle ok, still alittle rough when in gear. also hesitates (sometimes) when taking off from a stop.
Old Apr 11, 2005 | 07:12 PM
Default RE: now where?
Maybe the coolant temp sensor.Maybe it isn't giving more gas when the car is cold.
Old Apr 12, 2005 | 12:24 AM
Carbuff's Avatar
Wavewright, it only takes a small speck of dirt in the intake butterfly to cause an erratic idle.
I believe you cleaned that once, and it DID change the symptom to what you are seeing now. So I think you need to clean it more thoroughly. Warm-up the engine, shut it down, and clean. Use plenty of Intake Cleaner Spray and carefully but completely wipe the entire circumference of the butterfly and it's mating surfaces. Repeat this until you can wipe it with a clean cloth and no residue is collected. Then start the engine, it will run rough because it is burning the cleaner, but it should smooth out within a mile or two.
There are other methods of cleaning too, lets see if this one works this time.
Atwell Haines
'94 940 wagon
NJ
Old Apr 12, 2005 | 03:05 PM
wavewright's Avatar
cleaned throttle body thoroughly. have to wait for car to cool off to see it that fixed it. also i think i hear a vacuum leak but i cant fine where it could be. it sounds like its coming from the 3rd and 4th injectors. any ideas? the only thing i can think is that its the hose coming from the crankcase breather to the intake manifold, its missing, need to order whole assembly. but would that be audible coming from the crankcase?
Old Apr 12, 2005 | 04:46 PM
Might be but spray around the engine with it running using the carb cleaner.If the idle changes there is a leak there.
Old Apr 12, 2005 | 05:11 PM
wavewright's Avatar
tried the carb cleaner trick, nothing. could it be the fuel pressure regulator membrane. it that on the intake manifold?
Old Apr 12, 2005 | 09:16 PM
The fuel pressure regulator is on the front end of the fuelrail.There is a vaccum line that runs from it to the side of the intake.Remove the vaccum line and see if there is gas in it.If there is gas it is really bad.But it still may be bad if there is no gas.
seventeenhands
Oct 13, 2014 10:42 PM
Blondy44458
Jul 30, 2005 09:27 AM
Georgia Boy
Feb 20, 2005 08:30 PM
Thudpucker
Dec 9, 2004 03:39 AM
Steamroll9
Dec 7, 2004 09:56 PM
