obd 1 code reader
Old Jun 29, 2007 | 01:22 AM
Beardog's Avatar
Default obd 1 code reader
I have a 89 740gl. when checking the codes, i put the diode in the number 6 slot and activated the reader. the code i got back was 1-1-1, which is an all clear code. when i switched the code to the number 2 slot, I got the code 1-2-1. if reading the codes from the bc website that means its" MAF sensor signal absent or faulty LH 2.4". Does it mean the same when the diode is in the #2 slot on the reader, or is there a different set of codes for that?
Old Jun 29, 2007 | 01:55 AM
alexl's Avatar
Default RE: obd 1 code reader
Hi Beardog,
From what I understand, slot #2 gives you fuel related codes and slot #6 gives you ignition related codes and the numbers thrown do not overlap, meaning there are no same numbers for either slots.
Hope this helps.
Old Jun 30, 2007 | 12:53 AM
Beardog's Avatar
yeah, this helps alot. it means i have to spend some money.
Davo96
Jan 5, 2018 12:09 AM
dagumol
Oct 21, 2010 05:32 PM
rmjryost
Oct 1, 2010 10:20 AM
Csaba
Sep 5, 2010 10:37 PM
tekimp
Jan 24, 2009 08:22 PM
