OBD-II test result question
Old Jun 26, 2008 | 11:24 PM
dadto5's Avatar
Default OBD-II test result question
1989 740GL Wagon, Automatic, Air.
Fuelcode results
1-2-1 MAS this is after I pulled it with the engine running, it reset fine after clearing codes
3-1-1 Speedometer signal What effect will this have?? Speedo does seem to stick, but I thought it was a gear
Ignition test code results
1-4-4 Bad fuel injection relay; faulty wiring from LH to EZK; bad LH module WHAT IS LH and EZK
2-3-4 Faulty wiring or TPS; TPS adjusted incorrectly. But tested ok in the Mode 2 test.
Cleared all codes and made some adjustments.
Then ran a full mode 2 test with the following results;
I did not get a RPM test code, I did not get compressor OK code , and I did not get Engine idle code. Not sure why I didn't get RPM test code, it tested fine when I pulled the coil and cranked.
Then ran full mode 3 injection test with the following: Fuel injector tested ok, IAC tested OK (sounds like flapper being picked up and dropped), I did not get cold start valve test, I did not get a radio suppression relay (I assume it runs the pump momentarily), and I did not get fuel pump relay test (I assume it runs the pump momentarily) But the car starts and drives? Anyone have any ideas.
Car occasionally acts as if Engine lacks power; stalls; doesn't start or is jerky, I assumed a injector relay which was confirmed by the OBD code 1-4-4.
I know this is long and discombobulated.
Old Jun 27, 2008 | 08:08 PM
Default RE: OBD-II test result question
First year and model please.
Then I can give you more info from there.
Old Jun 28, 2008 | 03:25 AM
dadto5's Avatar
Can't believe I missed the most imporant part.
1989 740GL wagon Automatic w/air
Old Jun 29, 2008 | 08:04 AM
Ok now the code comes back right away after clearing?
The speedo's on these things are known to burn up all the time and act really wacky.
Another quiestion do you have a Regina or Bosch ingition system?
(Bosch round coil Regina square coil.)
Old Jun 29, 2008 | 03:59 PM
dadto5's Avatar
Fuel codes 3-1-1
injectioncodes 1-4-4
2-3-4
All came back. Mode 2 and 3 tests were done after the cleaning.
Have Bosch system (round coil onpassenger side by shock mount). But the codes I get from here make it seem I have a Regina system. This is why I'm so confussed. I'm trying to avoid just pulling and replacing relays, but that's where I'm at. There seems there might be TOO much information online for Volvos
Know aboujt the speedo, just surprised it sends a code. Wanted to make sure it wasn't something more.
analogies
May 5, 2013 02:01 PM
Beachbum
Sep 10, 2009 02:38 PM
seattlekal
Sep 8, 2008 04:03 PM
Grover
Feb 5, 2008 07:58 PM
