Odometer
Old Jun 26, 2023 | 06:41 PM
W4RO7's Avatar
Default Odometer
Hey I'm new to this forum but I've just bought this 89 240 dl and the speedometer and odometer aren't working I checked to see if that plastic gear was broken but it doesn't seem to be the problem but I did notice when I was taking it off some of the cables weren't connect does anyone have a diagram or maybe pictures of how the connections go? I would really appreciate it!
Old Jun 26, 2023 | 07:30 PM
89 240 has an electronic speedo. The sender for it is in the differential.
Wiring to the speedo is obvious - it's the only thing that plugs into the back of the actual speedo.
Pictures of the instrument cluster are on this site
https://cleanflametrap.com/tempFaker.html
"I did notice when I was taking it off some of the cables weren't connect does anyone have a diagram" - a word of caution - there is an extra unused wire on some cars behind the dash - if you plug it into a place you find on the instrument cluster - you will fry the speedometer! So - only connect what you disconnected!
Danbo_Brick
Jun 7, 2018 11:45 PM
boo266
Apr 12, 2011 01:50 PM
joanvito
Jul 18, 2007 08:31 PM
kav381
Sep 15, 2006 08:40 AM
88_240_DL
Mar 26, 2005 03:14 PM
