Odometer 1990 740GL Rex
Old Jan 21, 2006 | 01:53 PM
igtc's Avatar
Default Odometer 1990 740GL Rex
Hello all,
I am new to this forum, but not others. I am currently in the process of completing a head gasket change today. 2 Saturdays, on weekends work!
Anyway, I completed a post on a different forum as follows:
I bought this car about 3 years ago. I moved from Austin, to Fort Worth (180 miles due north)May '04. The winters are colder here on avg 5-10 degrees, daily. I know it's nothing compared to some other places. This did not have this problem prior to this winter.
However, this year I obtained a job at DFW airport only 27 miles away. I am just as ticked off about gas prices, as the rest of you. But since temps have dropped lately, I can't get accurate gas milage readings.
I work 4 days a week, overnight, and rarely use my vehicle the other days. So on my way home in the morning, I allow my brick to warm up no more than 10 minutes.
I begin driving, and notice my only my odometer is not working. All other gauges work fine. After whatever temperature the car decides to reach (warmed-up), the odometer begins working, and works until it sits in the cold for more than 4 hours or so.
After getting home, sleeping, and up again. I run errands, and other things. Odometer doesn't seems to fail.
What can I get to to warm up faster to get the odometer to get to operating temps, in the morning.
I have lost about 300-500 miles so far. Last year, when gas prices began rising, and I drove 44 miles to work, in the colder temps, it did not do this. Please Help!
Re: In reply to some of the responses I had received, I removed the cluster, and speedo/odometer assy. This was an attempt to unstick the gears, and/or check for broken teeth. There was not bad physical evidence. I was not able to access the gears, to the odometer, due to the metal, unremovable case over this one section in the center. I wish I had a digital camera to show pix of this. I had re-assembled, and driven with same problem on cold days.
Should I spend the money to replace it, or do you have any additional hints?
After I complete the head gasket job today, I will begin working on odometer problem, next weekend. Again, only Odometer stops, speedo is good.
Thanks for the long-windedness.
Kevin
1990 740GL Rex 215K
volvo745newbie
May 20, 2015 12:07 PM
frstephen1
Nov 1, 2013 06:50 PM
stereomonostereo
Apr 16, 2013 04:04 PM
jungletrekker
Dec 20, 2012 01:43 AM
rtaylo
Feb 13, 2011 11:41 PM
