Odometer problems
The odometer on my 1989 240DL has stopped working. This occurred after I removed the instrumental panel to replace some bulbs and the water temperature gauge. After reconnecting and reinstalling, everything works fine except the odometer. The speedometer is working perfectly, though.
I did some research and saw that this problem can be caused by stripped/worn gears inside the speedometer housing. So I pulled it and checked all the gears but they all look brand new. I manually rotated the gears inside the housing to rule out a mechanical jam. I cleaned all the connections (which seemed unnecessary since the speedometer is working).
I am now thinking it might be the motor or VDO board on the speedometer/odometer. Does anyone have ANY ideas or suggestions?
Thanks.
Thanks.
I have the same problem but do not wish to spend the $435 for a new speedo/odometer If you come up with a solution let me know. I am thinking along the lines of an autometer programable speedo I think they cost about$ 110. I am wonering if I can find one that will fit.
Hello Guys
I just joined the forum. With respect to the inoperable odometer, I just purchased a 1989 240DL. I've the same problem, therefore I will be very interested in the fix. cuzzboy@direcway.com
I have not come up with a solution, but I did find this website that offers to fix speedometers/odometers. They specificially mention the problem with the Volvo speedometer/odometer.
I have not contacted them yet, but thought I would post this for anyone interested.
http://www.instrumentclusters.com/
I've got a similar problem, only that both the speedo and the odometer have both stopped. (Tach as well). I've checked the instruments, and the wiring for what I can.
Is there any way of testing the sensor using common tools? And what about the instrument cluster?
Any help would be gratefully appreciated.
Iain
Iain
I have found a guy that can fix them or rebuild them very less the cost and I just got a rebuilt one from him for 85 dollars and he even set the milage to what the car had on it very good guy to deal with lives in CA.
